Leakage... transfer. Sorted thanks!
- biggaz
02 Jan 2011 13:11 - 08 Jan 2011 16:15 #8650
by biggaz
Leakage... transfer. Sorted thanks! was created by biggaz
Right, whilst fitting the towbar, noticed a splatter of oil/fluid on the floor of the jimny kind of above the transfer box? on the rear side of it if you know what i mean?
So where the rear prop would go into the transfer? that kind of area... This common, has a seal gone or what....
I shall try to get a pic i think, like i should have :blush:
This what happens with no prop spacer and a lift or am i thinking totally wrong lol
Last edit: 08 Jan 2011 16:15 by biggaz.
- vitara_mad
02 Jan 2011 13:43 #8653
by vitara_mad
Replied by vitara_mad on topic Re: Something is leaking?
its a easy fix to replace a seal
- biggaz
02 Jan 2011 14:28 #8654
by biggaz
Replied by biggaz on topic Re: Something is leaking?
so will it be the transfer box seal?
how long before it causes damage?
- biggaz
02 Jan 2011 14:56 #8657
by biggaz
- vitara_mad
02 Jan 2011 14:59 #8658
by vitara_mad
Replied by vitara_mad on topic Re: Leakage... transfer?
if its coming out from the flange that the prop bolts to its best to get it sorted asap its only couple of £££ for a seal.
02 Jan 2011 16:36 #8659
Replied by mlines on topic Re: Leakage... transfer?
Looks like the oil seal. If its a manual transfer box (the one with the lever and not the buttons) then the oil seal is here:
store.bigjimny.com/index.php?act=viewProd&productId=11
Time to create page: 0.226 seconds
