Leakage... transfer. Sorted thanks!
05 Jan 2011 16:12 - 05 Jan 2011 16:34 #8919 by facade
Replied by facade on topic Re: Leakage... transfer?
biggaz wrote: Oh...... and its 0.8 ltr of 75/90 oil yeh?
Probably nearer a litre if not just over. Suzuki seem to have no idea how to measure volumes.
I ended up running out to buy an extra can when I did the gearbox and transfer on mine, so I bought an extra litre over the book when I did the axle oil, and used most of it.
Last edit: 05 Jan 2011 16:34 by facade.
  • biggaz
05 Jan 2011 16:42 #8921 by biggaz
Replied by biggaz on topic Re: Leakage... transfer?
nice one, cheers for the info!
05 Jan 2011 16:55 #8923 by facade
The "correct" way is to add the volume of oil in the book, stick the bung in and drive off. :ohmy:
Then when you check the oil at the service, you add extra until it just starts to drip out, i.e. reaches the threads in the filler hole.
So I just miss out a step and fill it until it starts to come out, as that is how I would have checked it, but I got a lot more in than the handbook said, with the price of 75/90 synthetic I bought exactly enough.
Not too happy with the synthetic, it won't go into 1st easily when it is cold, I'm sure it used to before :whistle:
  • biggaz
05 Jan 2011 17:14 #8924 by biggaz
ah, i shall fill till it reaches the top! Thanks!
Is it easy to get to the filler/plug whilst box is on?
05 Jan 2011 19:07 #8932 by facade
Transfer box, I think so.
Gearbox probably not, I can't remember, because
I use an oil syringe from Machinemart
www.machinemart.co.uk/shop/product/detai...l-transfer-equipment
I dare say eBay would throw up something similar.
makes topping up gearboxes and axles very easy.
(I use it on my 'bike too, I made a hollow dipstick from brake pipe and a brass bush, just overfill and then suck the oil back out through the tube until it stops sucking, then the level is spot on)
  • biggaz
05 Jan 2011 19:11 #8933 by biggaz
hmm, handy!
Time to create page: 0.154 seconds
