Brakes pulling to one side
16 Dec 2010 07:05 #7647 by mlines
Thats great info, I have a caliper refurb kit in the post as I intend to strip it all down and get them fully working. I will work through everyones suggestions along the way although I will not be using copper grease on the rubbers as I made that mistake last time!.
The red grease is new but very stiff because of the cold. I will clean it out and re-apply, perhaps warming it in the house for a while before applying to ensure its more of a smear rather than a lump.
Pictures and write will follow!
18 Dec 2010 19:24 #7771 by mlines
Well,i have found out what the problem is, pictures will follow. However before that another quick question. When reassembling the caliper is it easier to fit the piston boot first and push the piston through it, or push the piston in first and the squeeze the boot into the gap?
18 Dec 2010 19:29 #7772 by Garry
mlines wrote: Well,i have found out what the problem is, pictures will follow. However before that another quick question. When reassembling the caliper is it easier to fit the piston boot first and push the piston through it, or push the piston in first and the squeeze the boot into the gap?
Fit the piston boot first, then the piston.
i done this last weekend as my brakes were siezed solid. the pistons were badly pitted, quick clean up and they went back in and now work fine.
also on another note about the rubber seals on the sliders, i had them on yet my sliders siezed badly, i have had them off for about about 7 months now, i take them out now and again to cover in copper grease and they have been problem free ever since.
18 Dec 2010 19:45 #7773 by mlines
Thanks, thats great. Onwards with the rebuild!
18 Dec 2010 21:05 #7781 by mlines
18 Dec 2010 22:03 #7790 by facade
Glad you found the problem.
Well done on the write-up too.
Can I suggest something?
You once told me that the part numbers for the two metal sliders were different, even though they looked the same to me, so it must matter that they don't get mixed up. I didn't measure them, I just replaced the damaged rubber on mine.
Usually when I rebuild a calliper, I pump some fluid in to make sure the pistons are going to come out, and pump any seized ones right out whilst the brake pipe is still connected. Lucky that there is a nice hole to drift these out with on the Jimny.
If the pistons are pitted, and the pitting will go through the fluid seal when new pads are fitted they must be replaced. Sounds as though you caught yours in time.
Enjoy the rest of the job, if you don't have ABS, the brake bleeding is easy.
I made a big mistake doing mine. Although I only removed a front calliper, and didn't therefore need to bleed the rears, I broke rule #1 (DON'T MESS!) and thought I would bleed the rears, and flush the old brake fluid out. There is only 1 nipple, on the passenger side, and it came undone slightly, then seized solid with fluid leaking, and wouldn't move either way. Naturally, this was at 5:00 on a Saturday, and I needed the car on Monday.
With prayers to various Deities I forced the nipple out, expecting from the feel of it to remove all the threads from the casting with it, cleaned it up with a wire brush, then put it back in, bled the rears, and nipped it back up. It hasn't leaked or blown out-- yet :unsure:
Time to create page: 0.345 seconds
