Brakes pulling to one side
  • Skinhead
15 Oct 2012 19:15 #50348 by Skinhead
Replied by Skinhead on topic Brakes pulling to one side
Gromit wrote: The sliders as people call them are the brake caliper pistons that seize in the caliper mounting causing the brake on that wheel work poorly which makes the other brake pull the car to that side.
Example - Seized caliper piston on right front wheel will make the car pull to the left !
Cheers mate, will take caliper off tomorrow and have a play. Mind doest pull when braking, it turns! Could drive round a small roundabout!
  • markyp2000
15 Oct 2012 19:27 #50352 by markyp2000
Replied by markyp2000 on topic Brakes pulling to one side
Seized caliper piston on right front wheel will make the car pull to the right as the brake wont relise and make it come on before the other/left brake because the brake pressure is higher than the relise pressure so the piston comes out but wont get pushed back in
  • supergaz
15 Oct 2012 19:29 #50353 by supergaz
Replied by supergaz on topic Brakes pulling to one side
Just remember not to use WD40 to clean them!
  • Skinhead
15 Oct 2012 19:33 #50354 by Skinhead
Im pretty sure its the passanger side not working, it drives in a straight line until i brake, the brakes are realy poor an it turns to the right.
  • supergaz
15 Oct 2012 19:34 - 15 Oct 2012 19:36 #50355 by supergaz
Jack up the front and give the front wheels a spin, you may feel one side binding.
Last edit: 15 Oct 2012 19:36 by supergaz.
  • Skinhead
15 Oct 2012 19:37 #50357 by Skinhead
supergaz wrote: Just remember not to use WD40 to clean them!
Why not??? Thats what i was going to do, do i use that red grease or what ever it is?
Time to create page: 0.166 seconds
