Brakes pulling to one side
  • markyp2000
15 Oct 2012 19:41 #50359 by markyp2000
Replied by markyp2000 on topic Brakes pulling to one side
it will attact the seal on the piston if it pulling to the right it will most probable be the right brake that has a problem
when reasemberling use new brake fluid to lube up the piston and seal
  • supergaz
15 Oct 2012 19:42 #50360 by supergaz
Replied by supergaz on topic Brakes pulling to one side
WD40 will cause the rubbers to swell up and stick more, Use brake & clutch cleaner.
The only grease I use on my sliders is red rubber grease, and copper grease on the back of the pads.
Lithium grease will attack rubber.
  • markyp2000
15 Oct 2012 19:51 #50364 by markyp2000
on the sliders i used normal gease the way i cleaned mine was to put a nut and bold though the middle and do it up tight then put some valve grinding paste on it then get a socket on a drill atachment and spin it up moving it in and out cleans it up a treat and mine has never got stuck again
15 Oct 2012 19:56 #50365 by mlines
Replied by mlines on topic Brakes pulling to one side
  • Skinhead
15 Oct 2012 20:02 #50367 by Skinhead
Replied by Skinhead on topic Brakes pulling to one side
Im still sure its my left caliper not braking but i will clean both sides anyway. So im using brake an clutch cleaner an red rubber grease, wish me luck.
  • Gromit
15 Oct 2012 21:07 #50381 by Gromit
Replied by Gromit on topic Brakes pulling to one side
markyp2000 wrote:
Gromit wrote: The sliders as people call them are the brake caliper pistons that seize in the caliper mounting causing the brake on that wheel work poorly which makes the other brake pull the car to that side.
Example - Seized caliper piston on right front wheel will make the car pull to the left !
Seized caliper piston on right front wheel will make the car pull to the right as the brake wont relise and make it come on before the other/left brake because the brake pressure is higher than the relise pressure so the piston comes out but wont get pushed back in
No mate, under braking conditions the seized caliper will not work and the good brake works and pulls the car to that side - brake steering !!!!
Time to create page: 0.192 seconds
