Brakes pulling to one side
  • markyp2000
15 Oct 2012 21:58 #50388 by markyp2000
Replied by markyp2000 on topic Brakes pulling to one side
well in my 17years of working on cars a stuck brake does as i say but if its realy jamed then yer it wouldnt work
so if a piston is stuck fast with rust on the pad side of the piston what stops it moving out NOTHING what stops it moving in is the rust thus the brake is clamping the pads more than the other free piston the othe side so the stuck caliper comes on first as it has got the pads clamped slightly thus pulling on the stuck side first
so hoow would you move a stuck piston either pump it out with the brake pedel or if in a work shop some times use an air line blower
  • v8dougie
17 Oct 2012 10:57 #50541 by v8dougie
Replied by v8dougie on topic Brakes pulling to one side
If after checking both pistons and calipers and sliding pins, changing fluid and checking disks and pads, you still have an issue, consider changing the flexible brake pipes. I had a very bad pull when braking, changed/checked everything and it was all okay, changed the flexible brake pipe and it was fixed. Weird thing was the pipe looked absolutely fine, it must have perished inside.
HTH
  • Skinhead
17 Oct 2012 12:09 #50558 by Skinhead
Replied by Skinhead on topic Brakes pulling to one side
Ive just finished, it was 1 of the sliders on the passanger side, it wouldnt move at all, i had to use a hammer and a little metal bar to get it out, then cleaned and greased an now its fine. Thanks everyone
Time to create page: 0.219 seconds
