2WD/4WD problem
04 May 2026 07:23 #264356 by Busta
Replied by Busta on topic 2WD/4WD problem
Please don't keep driving if the wheel bearing has failed.
A common cause for a hub to engage itself unprompted is a leaking vacuum solenoid. There are 2 solenoids under the cars battery, one for lock and one for unlock. They can be stripped and cleaned. Swapping the 2 solenoids around is a good way to diagnose this issue.
The following user(s) said Thank You: finjim
20 May 2026 18:46 #264474 by finjim
Replied by finjim on topic 2WD/4WD problem
Hi!
My problem is solved.
I got my Jimny from the carage. The damaged wheel bearing on the left front wheel was replaced. The 2WD/4WD started working normally after the bearing was replaced.
As I mentioned earlier, when troubleshooting the problem, I replaced the original vacuum hoses with new ones. That made the 2WD/4WD engagement much smoother. Apparently, there was a leak in the rusted metal pipes as well.
But the real problem at this point was a failed wheel bearing.
Thanks everyone for your help!
Time to create page: 0.067 seconds
