2WD/4WD problem
30 Apr 2026 09:41 #264326
by finjim
2WD/4WD problem was created by finjim
Hi!
I have a Suzuki Jimny, model year 2013. A couple of weeks ago, the 2WD/4WD started to have symptoms.
When driving with 2WD, there is a wobbly metallic sound from the left front wheel when the speed reaches 40-50 km/h. The sound sounds like metal catching on metal and spinning, as if a "4WD drive lock is dragging."
The sound stops when I switch on the 4WD and back to 2WD.
The sound does not return on the same journey, even if you stop. But when I turn off the car even for a moment, the sound comes back when I start driving again.
4WD and 2WD engage and disengage well. I have verified this with a jack.
I thought the problem could relate to the vacuum hoses. Some of the metal pipes were rusted. I replaced all the vacuum hoses under the car with new ones. The 4WD generally seems to engage more smoothly than before, but the problem did not go away. I also cleaned the filter that is connected to the solenoids.
Can anyone advise what to do next? I have been thinking of removing the vacuum hub and seeing what it looks like inside to see if I can find anything obvious. But I don't really know what to do.
30 Apr 2026 14:38 #264329
by facade
Replied by facade on topic 2WD/4WD problem
I'd start by taking off the vacuum hubs carefully, and see if one is engaged and the other is free.
If not, I'd put the right one back and drive it to see if the sound is there.
You can go for a quick drive with the hub off as long as you don't encounter a sandstorm or something, oil won't come out, the worry is dirt & grit getting in.
From your description the left hub could be half engaging, which is normally impossible, but it may be seizing on the splines, or you may have a leaky vacuum solenoid valve. You might have the hub on the other side engaged and that one free as an alternative.
If you are careful about removing a hub it will stay in it's engaged/disengaged position when you take it off so you can see what is happening
The following user(s) said Thank You: finjim
02 May 2026 16:04 - 02 May 2026 17:36 #264347
by finjim
Replied by finjim on topic 2WD/4WD problem
Thank you!
I removed both vacuum hubs with 2WD on.
The left hub's sleeve was up (picture attached). The right hub's sleeve was on the bottom with magnet.
Also the left hub's magnet works when you push the sleeve by hand.
Both vacuum hubs seems clean and ok.
When I put hubs back the right hub works fine, but the left hub's problem remains.
For me it seems that the problem has to be in left vacuum hub, because I have changed the vacuum hoses and the right vacuum hub works fine. So I assume that the problem must exist after T-joint in the left line. But I don't understand what could be broken because everything seems ok and the system seems quite simple.
Last edit: 02 May 2026 17:36 by finjim.
- Thank you received: 2004
02 May 2026 17:36 #264348
Replied by Lambert on topic 2WD/4WD problem
Do you have access to a compressor? If so regulate the pressure down to about 15 psi and use a blow gun to clear the ports on the steering knuckle where the flexible pipes attach. Also the side that seems to work ok use to confirm that the flexible pipes are going to the same ports on the other side. They only really go to the right ones unless someone has really forced them as they are different lengths.
03 May 2026 01:13 #264350
by facade
The left hub was engaged, the right one free, I thought the noisy one would be the free one, (if you use your fingers you can rotate the inner splined part if the hub is free/disengaged.)
As Lambert says with the black outer hub off blow through the two short ports to make sure that they are clear. Changing the wheel bearing can block the ports with grease, one air passage is through the bearing.
If the bearing is failing there will be a vacuum leak and the hubs won't disengage (I'm fairly sure the disengage path is through the bearing and the engage is along side the CV joint) , the seal in the bearing (and the one round the CV joint) must be sound.
The pipes could be crossed over and the hub working backwards, or there could be a leak or blockage in the pipe that disengages it.
04 May 2026 05:57 #264355
by finjim
I continued investigating and blew out the vacuum channels with compressed air. They seemed free, the air flowed unhindered.
It turned out that the left wheel bearing in my car seems to be at the end of its life. Since this seems to be related to the vacuum, I expect to get my car to the garage in a couple of weeks. I can't change the bearing myself.
I'll update the situation here as it progresses.
Thanks for the quick and friendly replies and advice!
Time to create page: 0.109 seconds
