Jimny Gen3 87/17% TG-kit, low geared transfer case, push button.
24 Apr 2025 12:01 #260209
I cut a trip short last year after doing a day of exploring in the mountains going up too many steep hills.
As everything else looks OK inside I think the high range sprockets for the chain are too worn.
But then again the noise has been there since i put the gears in it. It just has slowly gotten worse so might not be so dramatic, no problem until the chain start to slip wich i felt happen with the last chain that was in it and well stretched.
Worn spockets make the chain stretch more easy too.
My transfer case had maybe 100000km on it when I put the gears in. Now approx 150000km so there is still a lot of miles in a low range kit.
Not sure what to do next though. Guess i 'll just drive until it blows, and see then what the next chapter is.
Buy a 2004 jimny maybe so I can go for the 4.16 SJ transfer with no chain.
Or maybe dump the gen3 all together and finish building up my lwb SJ416 on 31's.
Replied by yakuza on topic Jimny Gen3 low geared transfer case, push button.
Seriously considering taking the spare transfer box with me to Denmark. That is how painful it is.Just out of interest how cataclysmicly loud are these gears? Obviously enough for you to think it needed looking at but annoying, unpleasant or painful? I ask as I keep getting drawn to their 15/104 set for the automatic which I want with 235s to take the top end out the autos gearing.
- Thank you received: 1999
24 Apr 2025 16:17 #260211
Replied by Lambert on topic Jimny Gen3 low geared transfer case, push button.
So potentially what you are saying is that if one were to look at the regear as an opportunity to build a fully new box into a used case it could be entirely reasonable for a good number of miles/years?
25 Apr 2025 12:29 #260224
Yes, i would do it again.
The added drivability with 235's and the lots of fun i had with the very low low gear ratio make it still worth it.
Even though my case was worn and still is, I am still going at 50000km and will continue. And I have not been nice to it. And while the case still goes, i have broken a diff and a gearbox from the added power.
It would be smart to start with a low milage donor case, change any bearings with play and, change the chain when doing the regear.
But i got 50000km saying it is not nescessary.
Yesterday I did a stupid thing and backed up a steep offroad trail with the trailer to fetch my fire wood.
Low gear and locker on but still got a fight.
Forgot to release the trailer brakes going down and a bit up to get to the road, so pulled the trailer full of fire wood out of there on stiff wheels.
5-600kg of birch.
So much added pulling power from the low gears.
5-600kg of birch.
03 May 2025 00:26 #260296
by JimnyCol
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
Replied by JimnyCol on topic Jimny Gen3 87/17% TG-kit, low geared transfer case, push button.
Having tried for a few months now this very same kit 17/87 from Trail Gear, with 235/75 R15 tires, I can say the only loud noise is going up hill and when moving the car from a standstill, e.g. semaphore, it will always rattle a lot, only first and second gear, but never had this rattle downhill. It is to me it's similar to the noise I had when I had a worn out gearbox support. It sounds more or less like when you have to scrape the pots off the coal after cooking with wood.
06 May 2025 16:05 #260317
Replied by yakuza on topic Jimny Gen3 87/17% TG-kit, low geared transfer case, push button.
My noise is only at torque like taking off hard or uphill or while pulling a trailer. Only at load and as you say only in first and a bit less in second.
Inspected all the bearings and all is good inside. New chain last year.
I have settled with it. It Will live as long as it Does.
22 May 2025 10:42 - 22 May 2025 10:46 #260544
So managed to get to Denmark and back and around with the transfer case. Ran good and noises did not get worse during the approx 2500km's.
But I used a gear oil that foamed alot (my own theory based on experience from work) so there was gear oil coming out of the vent on top of it, ran down the case and got splattered all over the rear of my car and the trailer. refilled gear oil during the trip half a liter or so. My guess is that the "cheap" 75/90 gear oil I used this time have bad or no anti foaming additives.
With the large gears in the small casing it makes for a perfect storm for foaming.
Could have lifted the vent up high but never got around to it. Could have bought a better gear oil, Could have made a better splash guard inside for the vent hole.
Dunno now.
Wouldn't pass MOT with the case and underside of the car full of oil.
Thinking of maybe try to add a reinforcement to the outside of the case like a cradle. Could be the noise come from twisting the gear housing at full torque.
I have the stronger transfer mounts allready so they are weldable.
Dunno now.
Last edit: 22 May 2025 10:46 by yakuza.
Time to create page: 0.784 seconds
