knocking noise from front wheel area
19 May 2024 15:37 #255992 by mag
Hi all , think i have a cv joint problem , car stationary , go from lock to lock and not all the time but sometimes , loud knock
from area of front o/s wheel  , doesn`t do it  every time , probably about 1 in 3 or 4 lock to locks , CV joint I`m thinking , would you agree ?
19 May 2024 16:09 - 19 May 2024 16:11 #255993 by DrRobin
It could be, but a cv joint normally makes a cracking sound when been driven at full lock, I doubt there would be any noise when stationary.
I would probably check other components first, e.g. wheel bearing, kingpin, steering linkage, coil spring, suspension bush, basically anything that can move when going lock to lock.
How old is your car?
Are you running bigger tyres, they’re not catching are they?
Robin
Last edit: 19 May 2024 16:11 by DrRobin.
19 May 2024 19:19 - 19 May 2024 19:21 #255997 by mag
2004 , 100K ON IT , WAS FINE LAST TIME OUT , KINGPINS NEED DOING AS LEAKING A BIT OF OIL FROM EASH SWIVEL BUT DON`T REALLY WANT TO SPEND MONEY ON KINGPINS IF CV GONE , ANY GOOD WAY TO TEST FOR CV ? STANDARD SUSPENSION AND TYRES
Last edit: 19 May 2024 19:21 by mag. Reason: HIT SUBMIT TOO SOON
19 May 2024 20:06 #255998 by fordem
CV joints, worn CV joints, will generally make a very distinctive repetitive "clicking" noise, but usually on full lock and with the vehicle under power, so accelerating - you say you're getting a knocking noise with the vehicle stationary - the chances of the noise being the CV joints is slim to non-existent.
19 May 2024 20:14 #255999 by mag
any ideas then , doesn`t appear to be suspension related , seems to come form wheel area , could it just be kingpin bearings ?? quite a loud " knock " when occurs but as i say , not all the time , does it when on the ground and with wheels off the ground
19 May 2024 22:51 #256004 by DrRobin
You say it happens even when jacked? In that case there is no load on the wheel or suspension and as the wheels are not going round, the only thing moving is the wheel hub on the kingpins, the steering rods and the steering box.
When you get the knock is their resistance before hand, e.g. something sticks then suddenly frees?
Whilst jacked can you feel any play, left/right or top/bottom?
The following user(s) said Thank You: mag
