knocking noise from front wheel area
- Thank you received: 1991
20 May 2024 03:27 #256006
Replied by Lambert on topic knocking noise from front wheel area
Years ago I chased a very similar problem and it turned out that the front panhard bar to axle bolt was just starting to back itself out. Tightened back to spec and noise gone. Took ages to find.
The following user(s) said Thank You: mag
20 May 2024 07:36 #256007
by facade
Replied by facade on topic knocking noise from front wheel area
I assume this happens in 2WD?
It could be a bad CV joint, when they break they fall apart, won't pivot properly and jam the steering so it won't go to full lock in one direction.
If you can't find anything else broken/worn, then you will have to examine it when you change the kingpin bearings- they are around £25 a side.
- Roger Fairclough
- Thank you received: 225
20 May 2024 08:03 #256008
by Roger Fairclough
Replied by Roger Fairclough on topic knocking noise from front wheel area
This needs 2 people and a mechanics stethoscope. One to turn and one to listen.
Roger
Roger
25 May 2024 12:01 #256093
by mag
Replied by mag on topic knocking noise from front wheel area
Had another look today and with wheels off ground , appears to do it on full right lock , 90% lock , doesn`t do it . Just before " clunk " you can feel
some resistance , then clunk . will then go approx 3 to to 4 more lock to locks before doing it again ..No play at wheel though both swivels show some signs of leaking . drivers side is worse , passenger side , very slight so both kingpins need doing but thinking the " clunk " is passenger CV joint ??
25 May 2024 12:03 #256094
by mag
yes , resistance on right full lock ( not 90% lock ) then clunk . no play left/ right or top /bottom
- Thank you received: 667
25 May 2024 15:48 #256096
Replied by DrRobin on topic knocking noise from front wheel area
It still doesn’t sound like a cv joint to me, unless it has completely collapsed. Then it would probably do it on both locks, not just the right.
It sounds more like something is sticking in the steering, then all of a sudden the power assistance overcomes it and it goes with a clunk.
It might be the steering rack or a bush, but could be the power assistance on the steering.
Time to create page: 0.364 seconds
