knocking noise from front wheel area
25 May 2024 19:16 #256098
by mag
Replied by mag on topic knocking noise from front wheel area
yeah , weird , if cv i`d expect it to do it when driving on the road more than it does , strange one.
think i`ll change both kingpins as leaking anyway and see what happens after that
- Thank you received: 1991
26 May 2024 04:25 #256100
Replied by Lambert on topic knocking noise from front wheel area
More often than not a restricted arc of movement in the steering is going to be a collapsed cv joint especially if associated with a significant snapping or cracking noise . Unfortunately as the drive shafts in the front end are double isolated from drive in normal conditions you don't get the same early warning of speed related clicks that you have in a front drive car.
The following user(s) said Thank You: mag
26 May 2024 11:46 #256103
by mag
Just been out in it and it`s the track rod end so thanks for all help , get one ordered and replace when I get kingpins done
Thanks again
Thanks again
Time to create page: 0.349 seconds
