4WD won't engage. No lights. Just hear relay click
04 Mar 2024 22:20 #254813 by DrRobin
If was the hubs or the vacuum system you would get a flashing green light.
I never had a problem with my Gen3, but I understand that the transfer box switch and cable are easily damaged.
Robin
05 Mar 2024 11:47 #254823 by greenmachine
same yr as mine , did you sort it?
05 Mar 2024 15:21 - 05 Mar 2024 16:53 #254830 by tomlil01
I took a look under the car and couldn't see any loose connections or broken wires.
I'm just trying to understand, is there normally a noise from the transfer box when switching from 2WD to 4WD, or is the only noise from the vacuum hubs?
I don't hear anything at all. Trying to narrow down the electrical problem.
Just trying to figure out whether you'd hear nothing if the 4WD switch had failed. My understanding is that if the switch has failed, the gears in the transfer box still change, and there is just no signal going back to the 4WD controller to say that it worked and the vacuum hubs can be locked.
Last edit: 05 Mar 2024 16:53 by tomlil01.
05 Mar 2024 17:48 #254832 by DrRobin
Hi,
See thie wiki article on how the 4WD system works.
www.bigjimny.com/mediawiki/index.php/4WD...ion_system_operation
Quick question, do you have a Push buttons or a lever to engage 4WD, the operation is slightly different.
I assume you have push buttons, when you select 4WD the controller moves the transfer box in to 4WD, once complete the green light starts flashing whilst the vac hubs are engaged. If the vac hubs engage and you get a vacuum detected the green light stays solid.
If the transfer box doesn't engage or the switch doesn't work to tell the 4WD controller that it can engage the vac hubs then you don't see the flashing green light and it doesn't even try to engage the hubs.
So for push buttons, you can hear a clunk from the transfer box, then a click from each hub, although you usually need to be close to the wheel to hear it.
If you are a lever then it is the lever which moves the transfer box and then everything else is the same as for push buttons.
Do you see a green light at all, even briefly?
Robin
05 Mar 2024 18:33 - 05 Mar 2024 18:33 #254835 by tomlil01
Thanks, Robin
That was my guess. I have the push buttons. No lights come on at all, even briefly.
I just got my brother to push the button when I had my head right next to the transfer box and you couldn't hear anything.
Does that suggest the controller is at fault? Can it be anything else?
Thanks
Last edit: 05 Mar 2024 18:33 by tomlil01.
05 Mar 2024 19:08 #254836 by greenmachine
take the switches out and test them with a fluke, and the power coming to them or not as the case maybe, there is a connection on the transfer box i think that was at fault on mine too.
Time to create page: 0.570 seconds
