4WD won't engage. No lights. Just hear relay click
- Thank you received: 673
06 Mar 2024 22:10 #254875
Replied by DrRobin on topic 4WD won't engage. No lights. Just hear relay click
I don’t know how easy the transfer box actuator is to change, probably hard. The wiki suggests giving it a tap with a mallet, but I have no idea.
I would check all of the fuses in both fuse boxes, just in case one has blown, it will be quick 8n comparison to fixing problems with the 4WD controller or transfer box.
07 Mar 2024 14:39 - 07 Mar 2024 14:39 #254884
by tomlil01
Replied by tomlil01 on topic 4WD won't engage. No lights. Just hear relay click
Checked every fuse in the car and all look ok.
Will take a look at the actuator and the wiring from the controller to the actuator at the weekend.
Will also try giving the actuator a knock!
Last edit: 07 Mar 2024 14:39 by tomlil01.
- greenmachine
- Senior Member
- Thank you received: 5
08 Mar 2024 11:14 #254905
by greenmachine
Replied by greenmachine on topic 4WD won't engage. No lights. Just hear relay click
test the switch, then test the wires to and from the switch to the TB, have you ever changed the TB oil?
08 Mar 2024 19:48 #254936
by tomlil01
You mean the switch on the TB that sends a signal to the controller to say the TB is in 4WD? I think the problem is before that because it's not even changing the gears in the TB to 4WD. Think it's the actuator or the wire to the actuator which should swap the gears to 4WD
TB oil was changed about a year or so ago when I got the reduction gears put in
08 Mar 2024 20:22 #254939
Has 4WD worked since you put the reduction gears in?
09 Mar 2024 18:19 #254975
by tomlil01
Yes, certainly was working since the reduction gears. I used it quite a number of times.
I tried tapping the actuator and didn't help.
Also cleaned all the connections with contact cleaner.
Lee
Lee
Time to create page: 0.223 seconds
