4WD won't engage. No lights. Just hear relay click
04 Mar 2024 17:58 #254796 by tomlil01
Hi, all,
I just finished changing my kingpin bearings.
I took the car out for a spin and all seemed good, however when I tried to engage 4WD, I just heard a relay click and nothing happened. No lights flash on the dash at all.
I am not sure whether this has anything to do with changing the kingpins. I probably haven't engaged 4WD for 6 months or more.
I don't think the vacuum cables can be the wrong way around, as I labelled them, and they don't even seem to reach the other way around.
Any advice much appreciated.
Thanks,
Lee
04 Mar 2024 19:24 #254804 by DrRobin
Have a look in the wiki for 4WD problems, about 3/4 of the way down
www.bigjimny.com/mediawiki/index.php/4WD..._failure_diagnostics
No 4WD light suggests failure of the transfer box switch, a problem in the wiring, a blown fuse or a 4WD controller failure.
The transfer case switch or wir8ng is the favourite failure.
Robin
The following user(s) said Thank You: tomlil01
04 Mar 2024 19:44 #254807 by greenmachine
whats the year? did the vac hubs work before ok?
04 Mar 2024 20:20 #254808 by tomlil01
Thanks, Robin. I found that article after posting my message. I couldn't find anything relevant initially.
I guess I'll need to get that checked out.
I did check the 4WD fuse and that's ok.
Lee
04 Mar 2024 20:21 #254809 by tomlil01
Year is 2005 (VVT). I don't know whether the hubs worked just before the kingpin change. In hindsight I should have checked, but I probably haven't tried to use 4WD for 6 months or more
04 Mar 2024 20:23 #254810 by tomlil01
I'll check the transfer box tomorrow. I did remove my transfer box guard recently to change the rear cat, so maybe I damaged something
Time to create page: 0.284 seconds
