4WD won't engage. No lights. Just hear relay click
04 Mar 2024 17:58 #254796
by tomlil01
4WD won't engage. No lights. Just hear relay click was created by tomlil01
Hi, all,
I just finished changing my kingpin bearings.
I took the car out for a spin and all seemed good, however when I tried to engage 4WD, I just heard a relay click and nothing happened. No lights flash on the dash at all.
I am not sure whether this has anything to do with changing the kingpins. I probably haven't engaged 4WD for 6 months or more.
I don't think the vacuum cables can be the wrong way around, as I labelled them, and they don't even seem to reach the other way around.
Any advice much appreciated.
Thanks,
Lee
Thanks,
Lee
- Thank you received: 673
04 Mar 2024 19:24 #254804
Replied by DrRobin on topic 4WD won't engage. No lights. Just hear relay click
Have a look in the wiki for 4WD problems, about 3/4 of the way down
www.bigjimny.com/mediawiki/index.php/4WD..._failure_diagnostics
No 4WD light suggests failure of the transfer box switch, a problem in the wiring, a blown fuse or a 4WD controller failure.
The transfer case switch or wir8ng is the favourite failure.
Robin
Robin
The following user(s) said Thank You: tomlil01
- greenmachine
- Senior Member
- Thank you received: 5
04 Mar 2024 19:44 #254807
by greenmachine
Replied by greenmachine on topic 4WD won't engage. No lights. Just hear relay click
whats the year? did the vac hubs work before ok?
04 Mar 2024 20:20 #254808
by tomlil01
Replied by tomlil01 on topic 4WD won't engage. No lights. Just hear relay click
Thanks, Robin. I found that article after posting my message. I couldn't find anything relevant initially.
I guess I'll need to get that checked out.
I did check the 4WD fuse and that's ok.
Lee
Lee
04 Mar 2024 20:21 #254809
by tomlil01
Year is 2005 (VVT). I don't know whether the hubs worked just before the kingpin change. In hindsight I should have checked, but I probably haven't tried to use 4WD for 6 months or more
04 Mar 2024 20:23 #254810
by tomlil01
I'll check the transfer box tomorrow. I did remove my transfer box guard recently to change the rear cat, so maybe I damaged something
