4WD and 4WD-L lights flashing
03 Oct 2024 06:26 #257776 by JimnyCol
In the UK the cost of replacing those parts would be significantly less than the cost of manual hubs.
Here in Colombia, a single automatic hub goes for 650 dollars (DERCO, Autozen, Suzuki authorized dealers)! On eBay for 178 dollars + shipping. That's why 150 dollars for both manual hubs is way cheaper and would stop the problem. And an original freewheel spindle must be imported and costs $220. Or eBay $158 + shipping. Crazy prices here. Last time I wanted to buy an original ignition coil and the price was over $190...
Once you have linked the wires in the vacuum switch connector it shouldn't matter what you do with the vacuum hoses, but leaving them looped or blocked is the best option.
Ok so no matter what I do with the vacuum hoses, right, but if I keep the system "as it is", I only got a flashing light, no double fast flashing lights error. If I start to mess with the connector bridging, I get the error.
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
28 Oct 2024 16:29 #258077 by JimnyCol
I have fitted manual hubs, stopped every vacuum hose and shortcircuited the connector but I still have flashing lights.
28 Oct 2024 21:32 #258082 by DrRobin
It could be the transfer case switch or failing that the 4WD controller.
29 Oct 2024 04:23 #258085 by Lambert
Yeah it sounds wire related. Be careful with the switch there's a tiny detent ball behind it that is determined to escape.
Time to create page: 0.317 seconds
