4WD and 4WD-L lights flashing
08 Feb 2024 17:27 #254142 by JimnyCol
4WD and 4WD-L lights start flashing randomly when driving in 2WD mode. They may keep flashing for half an hour, then stop, and then again. It doesn't matter if I'm moving or stalling.
Both 4WD and 4WD-low modes are working as they are supposed to. I have found no driving defects, except for the lights that keep flashing with the pattern in this video.
The mechanic checked for vacuum leaks and found nothing.
The electrician checked the 4WD module signal and made me change both switches in the transfer box, part 37630-76J20.
I have had these lights flashing for more than 5000 km and four months. Could you help me? What can I check now?
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
08 Feb 2024 19:07 #254144 by facade
The only thing left is the actuator on the transfer box, it has a limit switch that can go wrong.
Check all the wiring for broken wires/corroded connectors.
The following user(s) said Thank You: JimnyCol
08 Feb 2024 22:07 #254151 by JimnyCol
Hello, thank you for your answer, do you mean 29300-76J00 part? I can't find where it's located, do you have any diagram, additional hint?
08 Feb 2024 22:14 #254152 by Phaeton
Sorry this might be totally irrelevant so if it is let me know & I will delete but it may get you on the right track  www.asapnetwork.org/sites/default/files/...ion/304505-3-INS.pdf
08 Feb 2024 23:33 #254154 by facade
No idea on part number, my Gen 3 had a lever transfer box, but here is all I have
This browser does not support PDFs. Please download the PDF to view it: Download PDF
14 Feb 2024 07:52 - 14 Feb 2024 07:54 #254291 by yakuza
Mine does this fast blinking when the vacuum switch valves (below the battery) freeze up and stick during cold and below -5 C periods. I hold a bag of warm water to the valves and the blinking calms down and I can shift it into 4x4 again. Never happens when it is warm.
I had the valves out and lubed and dried them a few times to the best of my ability so they work much better now but sometimes they still stick.
I have just bought a new to me set of valves used that I will swap in soon.
Or maybe next year as there is most likely not coming more cold weather now, I am ready for the spring in just a few weeks!
Last edit: 14 Feb 2024 07:54 by yakuza.
Time to create page: 0.168 seconds
