Bad running engine when it gets to temperature
22 Jan 2024 15:05 #253663 by Phaeton
The padlock is the immobiliser, are you saying that is starts, gets up to temperature, then the padlock light comes on & the engine then stops? Or are you saying it fires & runs for a few seconds then stops?
22 Jan 2024 19:02 #253670 by Gavin
The engine runs well until it gets hot. Then the immobiliser light flashes and it won’t Rev. I’ve tried to load a video.
It won’t Rev above 1000 and seems to be misfiring.
25 Jan 2024 11:19 #253736 by Gavin
The engine runs fine when cold. When it gets to temperature the immobiliser light flashes and it won’t Rev up. It keeps running on tick over no light. When you Rev it the light flashes and and the Rev counter just bounces and the engine misfires
29 Jan 2024 19:25 #253881 by Gavin
When hot the padlock light flashes. The engine keeps running but seems to turn off then on again when you try to Rev or drive.
On tick over runs ok.
29 Jan 2024 21:11 #253882 by Busta
What you are describing sounds exactly like the classic crank sensor failure on the M13a engines (assuming yours is a hard top). You say you've already changed it but I'd recommend visiting it again. I've heard people having issues with the cheaper pattern part sensors even when new.
29 Jan 2024 21:50 #253883 by Gavin
I will get another crank sensor tomorrow. Thank you for the reply.
Time to create page: 0.104 seconds
