Bad running engine when it gets to temperature
21 Jan 2024 16:01 #253636 by Gavin
Engine won’t run when it gets to temperature. Rev counter bounce just over 10 thousand, bottom two lights flash mainly the bottom one.
21 Jan 2024 17:35 #253641 by Lambert
First things first what year is your jimny as there's differences over time. Secondly have you had a code reader plugged in?
21 Jan 2024 19:49 #253649 by facade
A common reason for the engine to play up when hot is the crank sensor.
This usually makes the engine stop until the sensor cools down, it affects the rev counter (it reads zero) as there is no signal that the engine is rotating.
Bouncing up to 10,000 rpm (does it even go that high? I don't think even the 600cc would have one that goes to 10,000) maybe an intermittent connection somewhere,
  • rogerzilla
22 Jan 2024 11:00 #253659 by rogerzilla
Replied by rogerzilla on topic Bad running engine when it gets to temperature
What lights?  Do you mean 1000rpm?
Crank sensor is certainly likely but coil packs can also develop cracks which open up when hot, causing misfires. In that case warning lights are less likely.
22 Jan 2024 14:19 #253661 by Gavin
Thanks for the replies.
Crank and cam sensor have been changed new coil packs. Yes 1000 revs.
Code reader says no faults.
It’s a 53 plate Jinny. The cat has been removed.
The light that flashes is the one with the padlock on it.
22 Jan 2024 14:21 #253662 by Gavin
Time to create page: 0.094 seconds
