engine swap
11 Dec 2022 15:50 #246304 by spotdoc67
engine swap was created by spotdoc67
Hi
I'm new to this site and too Jimny ownership.
I'm picking up a 2006 Jimny with a sick engine (head gasket gone, no idea what state the head is in).
Rather than fixing the engine (which is on 130k) I was thinking about replacing it.
I've seen a M13A from a Suzuki Swift (2005-110 for sale at a reasonable cost with 80k on.
Can someone let me know if this is also a VVT engine and will it fit in and connect up to the Jimny loom and gearbox?
many thanks
Tom
11 Dec 2022 16:05 #246305 by Busta
Replied by Busta on topic engine swap
Yes that age will be a VVT. But while you're at it you might as well fit a 1.5. It's exactly the same amount of work and the extra power is very welcome.
11 Dec 2022 16:48 #246306 by spotdoc67
Replied by spotdoc67 on topic engine swap
thanks
will keep an eye out for a 1.5
do they plug straight in to a Jimny loom
Tom
11 Dec 2022 17:49 #246308 by Busta
Yes, it's plug and play.
12 Dec 2022 09:21 #246318 by spotdoc67
just managed to track down a Suzuki Ignis 1.5 VVT engine!
Just checking....will the Ignis clutch be ok with the Jimny gearbox??
12 Dec 2022 09:23 - 12 Dec 2022 09:25 #246319 by yakuza
Replied by yakuza on topic engine swap
You will be using the jimny flywheel and clutch.
Edit: that said, they might be similiar or even equal. (SJ 1985), Jimny G and Jimny M all got the "same" clutch so might even be the same on other Suzukis.
Last edit: 12 Dec 2022 09:25 by yakuza.
Time to create page: 0.168 seconds
