M16a VVT engine swap
  • Twin Cam
09 Jul 2025 11:42 #261165 by Twin Cam
Replied by Twin Cam on topic M16a VVT engine swap
Throttle bodies. The liana M16a TB is 50mm the Jimmy is 46mm although the manifolds aperture is 50mm.
If used in standard form it will idle at 1500rpm when hot.
The idle control unit needs to be swopped/replaced with the one from the M13a TB same may apply to the TPS but I replaced mine anyway.
Time to create page: 0.293 seconds
