M16a VVT engine swap
29 Jul 2022 00:03 #244281
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
M16a VVT engine swap was created by Mike G
Hello folks,
Not been here for a while since I refurbed my jimny. I vowed that would be the last of the big jobs, but now I've gone and bought a Suzuki Swift sport 1.6 VVT engine to throw in. I've got a couple of questions that you knowledgeable gents may be able to help me with.
I'm going to be running the engine on the stock M13 ECU as I want the simplest engine swap to get me up and running, mainly so I don't have to get my shopping on the bike. I wondered if there was a piggy-back unit that you could use to manage fuelling and timing as I plan to take it to a rolling road for tuning eventually, just to make sure I'm using it as efficiently as possible with the new engine, air filter and exhaust. Perhaps the standard ECU can just be flashed? Hopefully a dyno tuner would have done a few swift sports, but maybe Jimny ecus are quite different? My stock ecu is from an 07.
Also, I know a lot of guys don't like the existing vacuum operated hub system, but I plan to keep this. I'm not sure if the vacuum pickup on the swift engine would be from the same place. I've not actually received the engine yet, so haven't been able to look. Has anyone who's done this mod felt the need to keep the existing vacuum system operational and if so, where did you pick up the vacuum line from?
Hopefully most of this will be a straight swap, as I've read a lot of posts on here and a few other places.
29 Jul 2022 08:52 #244285
by sniper
Replied by sniper on topic M16a VVT engine swap
The standard M13A VVT ecu with 1600 injectors is the compromise that most people run with when doing the M16A swap and it works ok, it gives a big improvement over the 1300. Fuelling is not super accurate though but at no additional cost, a fair compromise, that most are happy with.
The Denso ecu is supposedly writeable but I have never found someone able to do it.....
I recently had a standalone ECU fitted and the difference in tune is quite remarked, and in my mind, worth the cost of £1200. A bargain find at Dynotech in Ripley. Supply and install with rolling road set up. Have a look at my thread "tread lightly".
I would suggest getting the exhaust sorted before mapping, they respond really well to a free flowing system. Torque figures are much improved.
sniper
sniper
The following user(s) said Thank You: Mike G
29 Jul 2022 10:44 - 29 Jul 2022 10:49 #244287
by Busta
Replied by Busta on topic M16a VVT engine swap
RE vacuum hubs, if you look at your exisiting setup it's fed by just one small vacuum port on the inlet manifold. This should be very easy to replicate on the swift engine, either with an existing port or by adding your own.
ETA Presumably you will be using the Jimny manifold anyway, so the vacuum system will be unchanged.
Last edit: 29 Jul 2022 10:49 by Busta.
29 Jul 2022 13:54 #244288
by Mike G
Replied by Mike G on topic M16a VVT engine swap
Hi Sniper,
Been having a read if your thread. Very nicely done. Although I've been thinking of more ways to spend money that I don't have now after reading.
Ripley is a fair distance for me, but if the place near me in Aberdeen can't/won't do work on my engine, I may have to consider travelling a little further to get what I want. Not that many tuners with rolling roads up my way. But that will be a bit in the future for me once I've sorted out inlet and outlet stuff.
I already have a stainless system on the 1.3 (minus the manifold), however that may be worth considering if I can get one for a decent price. Did you just port your 4-2-1 to fit the 1.6? I would have to modify my existing system if I fitted one as the original manifold ends a bit higher up.
29 Jul 2022 14:01 #244289
by Mike G
Hi Busta,
For now I'm leaving the jimny manifold on, so that should be fine. But a new one might be on the cards before a tuning, as I would prefer the fuelling to be correct and not sure just porting the existing one will do. I'd feel cheated if I was missing out on some gains if I just spent a bit more on throttle body and manifold.
29 Jul 2022 14:26 #244291
by Old Neil
Replied by Old Neil on topic Re:M16a VVT engine swap
Hi Mike G
Very interesting project your doing a lot of potential, I've been wanting to do the same for some time but I'm in Australia and early swift sport motors are hard to get and been told after 2012 motors are harder to get sorted, be interested to see how yours works out
How hard is it to get swift sport engine over your way, would it be possible to ship one to Australia?
Sent from my SM-A336E using Tapatalk
Time to create page: 0.552 seconds
