Disc conversion with standard wheels
- Stevekennedy
- Thank you received: 1
11 Feb 2021 22:22 #232709
by Stevekennedy
Replied by Stevekennedy on topic Disc conversion with standard wheels
Ah yes good idea. I’m north wales by holywell.
- Roger Fairclough
- Thank you received: 225
12 Feb 2021 10:53 #232716
by Roger Fairclough
Replied by Roger Fairclough on topic Disc conversion with standard wheels
Please be aware that due to the way a ball race is built there is a degree of axial movement present even from new and this movement will progressively worsen with use. This means that the piston/pistons in the caliper will be pushed back as the car corners and when you brake the first part of pedal movement will just push the pistons back without actually causing any braking effort. Some years ago a friend with an SJ did this conversion and reckoned his pedal went half way to the floor before he had any retardation. Very disconcerting.
Roger
Roger
Time to create page: 0.077 seconds
