Re:Gen 4 Battery swap
- GeorgeC
12 Aug 2020 07:36 - 12 Aug 2020 07:57 #226544
by GeorgeC
Replied by GeorgeC on topic Gen 4 Battery swap
Lambert, it can be done by the Suzuki Method, as above, then you re-program all the things that drop out. Or, you can do what the battery suppliers do and provide a back up.
However, there are different local solutions in different places. Some remove and bench charge once a month. I top-up with solar once a week. Others have a Lithium Battery under the passenger seat and a DC/DC Converter to keep the starting battery up. All this because someone in Brussels decided Australia can't use the hi-output Alternator cause it makes too much CO2 for Europe! The Alternator produces 80Amp max and 60A+ at 1050rpm! But little of that current makes it to the battery.
If you read the Forum Topic "Tonka's poorly", you can see just how mean the computer can be if it thinks you have had enough Amps for that drive!
The Battery bloke also said the new Ford Ranger is just the same as the new Suzukis!
Last edit: 12 Aug 2020 07:57 by GeorgeC. Reason: + Ford Ranger!
12 Aug 2020 10:18 #226549
by Gadget
I think the need for a supplementary feed is only if you want to keep any logged fault codes in the system, the manual mentions disconnecting the battery if you're not using the car for a while - unlikely they'd say that if you had to take it to the dealer to get everyting working again (I hope!)
Replied by Gadget on topic Gen 4 Battery swap
Lambert wrote: Sorry I'm confused. Are you saying that on a gen4 you can't just disconnect the battery without a supplementary 12v supply or a trip to the dealer to get them to do it and or recode the car? That's mental if that's the case.
The following user(s) said Thank You: Lambert, GeorgeC
- GeorgeC
22 Aug 2020 04:06 #227145
by GeorgeC
All done!
Battery swapped, Car Serviced, new 0W-20 Oil.
Codes scanned, one Fault Code found, in hand with the Service Manager.
Today's Battery Resting Voltage is 12.73V, that is with just the Alternator re-changing the battery.
Now it just gets better!
- GeorgeC
30 Aug 2020 19:10 - 30 Aug 2020 19:15 #227568
by GeorgeC
My Joy was short lived, the Alternator was 'switched off' on the next drive! Suzuki sent the RAC Man on Saturday to switch the Alternator back on.
I am now looking for a lo-voltage alarm. I want to use in the 12V Accessory Socket to power it and set to 12.6Volts and to go off when the alternator is switched off. I can then stop and re-boot the car and the charging system and continue my drive.
Something simple please, a piezzo buzzer with a small switching circuit. I don't need any more computers or visual devices. I only have one eye and limited vision so an audible alarm is much better for me. I have asked on two Facebook Forums, no success. 40 years back I sold these things for boats and trucks.
thank you, George
thank you, George
Last edit: 30 Aug 2020 19:15 by GeorgeC.
31 Aug 2020 07:38 #227580
Replied by mlines on topic Re:Gen 4 Battery swap
How do you turn the alternator off and on?
- GeorgeC
31 Aug 2020 08:27 - 31 Aug 2020 20:40 #227582
by GeorgeC
Thank you for the help with the search, this one looks to be the goods! There is a video in the link.
www.mpja.com/Battery-Low-Voltage-Alarm/productinfo/35716%20MP/
or here:
www.aliexpress.com/item/32859037056.html...0_D_BwE&gclsrc=aw.ds
Replied by GeorgeC on topic Re:Gen 4 Battery swap
Hey that's my question! I've PM'd the latest 'fix'. Four hours after shopping, the battery resting voltage is 12.73V! :woohoo:mlines wrote: How do you turn the alternator off and on?
or here:
Last edit: 31 Aug 2020 20:40 by GeorgeC. Reason: The Video
