Re:ratio on diffs
06 Mar 2020 17:43 #219502
Replied by Riccy on topic ratio on diffs
Start with what year, engine and manual/auto you have, that usually points to the gearbox, transfer box and diffs fitted to it. If your pre 2005 its almost certainly the 3.9 ratio (if manual gearbox). after that year is usually 4.3.
Use the numbers you found in the link to input into grimmjeeper gear calculator (google it). It has a side by side comparison, showing wheel revolutions amongst other info. Very useful site. When I use it I try to compare my modified car to a standard one in the hope of keeping the gearing about right for all the changes.
06 Mar 2020 18:02 #219503
Replied by mlines on topic ratio on diffs
To answer your original question.
2 turns on the rear prop and one turn on the wheel is 2:1.
As you can see, there is no diff ratio of 2:1, there is only 3.90 and 4.090
Which would be 3.9 turns of the prop to one of the wheel or 4.090 turns of the prop to one of the wheel.
08 Mar 2020 09:23 #219583
by safari
so Martin my jimny is 1998 manual ,do i try on low gear cause i tried to turn the wheel on normal drive and on which gear should i try to see if mine is 3.90 or 4.090
tks again for the help
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic ratio on diffs
mlines wrote: To answer your original question.
08 Mar 2020 09:38 - 08 Mar 2020 09:42 #219584
Replied by mlines on topic Re:ratio on diffs
It will be 3.9
Going on low range will make no difference, the diff is after the transfer box.
Trying to see the rotation difference between 3.9 and 4.09 is difficult
If you thoroughly clean the carrier case you can sometimes read the part number stamped on it
Last edit: 08 Mar 2020 09:42 by mlines.
10 Mar 2020 09:10 #219674
by safari
Replied by safari on topic Re:ratio on diffs
tks again
Time to create page: 0.122 seconds
