Re:ratio on diffs
6 years 8 months ago #219461
by safari
if u worry u die if u dont worry u still die so why worry
ratio on diffs was created by safari
can someone help what diffs i have
when i turn the wheel is 1 wheel turn == 2 propshaft turns
want to see if there are lower diffs ratios
- Thank you received: 2004
6 years 8 months ago #219472
Replied by Lambert on topic ratio on diffs
If you look in the wiki in the Jimny information section all the ratios are there
6 years 8 months ago #219479
by safari
Replied by safari on topic ratio on diffs
where can i find them plsLambert wrote: If you look in the wiki in the Jimny information section all the ratios are there
6 years 8 months ago #219494
6 years 8 months ago #219495
by safari
but how to calculate with wheels on i am more confused now
1998 UK/EU G13B Manual 3.652 1.947 1.423 1.000 0.864 Manual 1.320 2.145 3.909
1998 UK/EU G13B Auto 2.962 1.515 1.000 0.738 N/A Manual 1.320 2.145 4.090
6 years 8 months ago #219501
Look up a site called grimjeeper it's a gearing calculator that allows you to input everything including main gearbox ratios transfer ratios diff ratio and tyre size and gives you wheel speed and engine rpm tables.
Time to create page: 0.108 seconds
