Re:ratio on diffs
06 Mar 2020 08:44 #219461
by safari
if u worry u die if u dont worry u still die so why worry
ratio on diffs was created by safari
can someone help what diffs i have
when i turn the wheel is 1 wheel turn == 2 propshaft turns
want to see if there are lower diffs ratios
- Thank you received: 2004
06 Mar 2020 10:14 #219472
Replied by Lambert on topic ratio on diffs
If you look in the wiki in the Jimny information section all the ratios are there
06 Mar 2020 12:06 #219479
by safari
Replied by safari on topic ratio on diffs
where can i find them plsLambert wrote: If you look in the wiki in the Jimny information section all the ratios are there
06 Mar 2020 14:49 #219494
06 Mar 2020 15:10 #219495
by safari
but how to calculate with wheels on i am more confused now
1998 UK/EU G13B Manual 3.652 1.947 1.423 1.000 0.864 Manual 1.320 2.145 3.909
1998 UK/EU G13B Auto 2.962 1.515 1.000 0.738 N/A Manual 1.320 2.145 4.090
06 Mar 2020 17:42 #219501
Look up a site called grimjeeper it's a gearing calculator that allows you to input everything including main gearbox ratios transfer ratios diff ratio and tyre size and gives you wheel speed and engine rpm tables.
