Re:Constantly flashing amber ABS light
- KT53
25 Sep 2019 13:06 #213848
by KT53
Constantly flashing amber ABS light was created by KT53
I have a 2003 Jimny 1.3 JLX mode MT, manual transmission, 90,000 miles on the clock. The ABS light is constantly flashing amber from the time the ignition is switched on until switched off. Diagnostics indicate no DTC's. The local garage has checked that the ABS is working as are the sensors. Removing the fuse makes the light glow continuously amber, indicating a fault. The light is not meant to flash at all.
I've been told this problem is an MOT failure, which would be dreadful for me, plus it all seems to be working correctly apart from a flashing light. Please ca anyone help? Thank you
- Max Headroom
- Banned
- Thank you received: 216
25 Sep 2019 13:19 #213849
by Max Headroom
Replied by Max Headroom on topic Constantly flashing amber ABS light
Hello KT53 and a BigJimny welcome to the forums.
I can't help you in this instance but I'm sure someone will be along soon with some good ideas and suggestions to help you solve the issue.
25 Sep 2019 13:24 #213850
Replied by mlines on topic Constantly flashing amber ABS light
- KT53
25 Sep 2019 14:05 #213852
by KT53
Replied by KT53 on topic Constantly flashing amber ABS light
Thank you Martin. Sadly, I have the technical ability of a pebble, but have bought a OBD2 scan tool and downloaded a Suzuki app which tells me that there are no faults on the ABS/ESP to clear. Do you think that getting someone to do the manual thing that the link suggested, will give a different answer? Thank you!
25 Sep 2019 14:07 #213853
Replied by mlines on topic Re:Constantly flashing amber ABS light
I think it might as depending on the age of the vehicle it is the only way to read the abs fault
The following user(s) said Thank You: KT53
- mickt
29 Sep 2019 12:02 #213998
by mickt
Replied by mickt on topic Re:Constantly flashing amber ABS light
If you enter your whereabouts area wise then a member might volunteer to help you out. I am in Stoke on Trent by the way.
Time to create page: 0.090 seconds
