Odd noise from engine?
14 Jan 2018 17:15 #188377 by Lambert
Replied by Lambert on topic Re:Odd noise from engine?
Ok thanks all. Will confirm fluid level. Cheers.
14 Jan 2018 17:30 #188381 by Busta
Replied by Busta on topic Odd noise from engine?
I'd say power steering belt tensioner too.
14 Jan 2018 18:25 #188386 by Lambert
Replied by Lambert on topic Odd noise from engine?
The tensioner was replaced about 2 years ago and the noise it made was very different, that and the tensioner is quiet.
14 Jan 2018 22:10 - 14 Jan 2018 22:11 #188394 by Scimike
Replied by Scimike on topic Odd noise from engine?
My money is on lack of PAS fluid. Not experienced with Jimny, but had Reliant Scimitar that made same noise when PAS sprang a leak. I am new to Jimny ownership so please ignore if wrong....
Mike
Last edit: 14 Jan 2018 22:11 by Scimike.
15 Jan 2018 05:00 #188399 by Lambert
Ok so i checked the fluid and it was close to full so I added at most 30ml to that. It was still quiet this morning starting from cold. If i didn't know better it almost sounded like a zip tie end in the fan but how it could have got in there i don't know because I have the extra heat exchanger for the air conditioning so i doubt it has come in from the front. I guess I will be keeping a close eye on it in the event of a repeat. Thanks all for the comments
15 Jan 2018 18:37 #188416 by Lambert
Right, all of you who suggested the pas tensioner could be onto something. The noise has altered and is no longer like a strimmer but is now what I would expect from a dying bearing. A replacement is on the way. Will see if it improves matters. Thanks again all.
Time to create page: 0.107 seconds
