Odd noise from engine?
- Thank you received: 2004
19 Jan 2018 11:44 #188569
Replied by Lambert on topic Odd noise from engine?
No the power steering belt tensioner. Would be 80 ish quid from dealer or martin does just the bearing for 15.
20 Jan 2018 22:02 #188643
by Mike G
Thanks, Generally, if I need anything Jimny I try to get from Martin. Question for you though, when you removed the tensioner, did you find that the bearing felt rough or smooth at all? Because, when I removed my tensioner last time during a belt change, I didn't feel any roughness or play of the bearing itself, which is why I put it right back without doing anything. Just curious as to what you found yourself.
Mike
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Odd noise from engine?
11/60 wrote: No the power steering belt tensioner. Would be 80 ish quid from dealer or martin does just the bearing for 15.
Mike
21 Jan 2018 03:07 #188650
With the tensioner in my hand i can just and i mean only just feel a tiny tiny little bit of latteral movement between the inner and outer bearing races, but it is definitely there. In the new bearing it is solid to the touch.
21 Jan 2018 21:35 #188687
by Mike G
Ah, thanks. Sounds like my one could be worth replacing then. Really didn't feel like a worn bearing, but it's not much cost to replace really. I'll give that a go.
11/60 wrote: With the tensioner in my hand i can just and i mean only just feel a tiny tiny little bit of latteral movement between the inner and outer bearing races, but it is definitely there. In the new bearing it is solid to the touch.
23 Jan 2018 20:34 #188784
by Mike G
OK,
Just for information, I did my tensioner bearing today.
I took a pic of the tensioner unit disassembled. Pressed the outer ring off first, then pressed the centre part out. The centre part holds back a metal ring (pictured), which isn't attached to the centre part. I used a bearing press to push off the outer ring, but for the centre part, I just put a big brass drift in a vice and smacked the centre out, holding the tensioner like I was cracking an egg as I did and it came out easily with a good few swift, stern smacks.
26 Apr 2018 20:40 #192207
by Bosanek
Replied by Bosanek on topic Odd noise from engine?
I also suspect that my power steering pump tensioner bearing is bad. However, my mechanic told me he can receive me only on Saturday (two days in advance) and then he's gone for a surgery, so I don't have the time to have the bearing delivered internationally from Martin.
So, can someone tell me which aftermarket bearing model / designation (like the ones from SKF, Koyo, Timken, NSK, etc.) is fully compatible? Is there some special attribute which I need to pay attention to (like some special lips, sealing, or something)?
Also, should any pulleys be replaced while replacing the driving belts? What about the water pump (when should it be replaced)?
Time to create page: 0.111 seconds
