Odd noise from engine?
youtube link to noise
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
- Thank you received: 2004
Busta wrote: I'm sure you already know but, you only need to replace the outer bearing part. The inner mounting bit just presses in. Like most suzuki bearings it's a standard size available from any good bearing shop.
I fell into the dealer trap on those last time round, not again. I do however have a spare I can build up onc3 the new bearing lands, minimum of down time, planned maintenance, etc.
11/60 wrote: Flash. Mine was similar to the video but a lot less pronounced. For the cost of a new bearing mine is quiet again. Bit of a faff to swap with everything in place but all done in 20 minutes after drifting the old one apart and back together.
Ah, which bearing is that, the main pulley bearing? Any idea of the bearing markings (sizing), I wouldn't mind replacing mine, it's driving me nuts and probably costing me MPG
