Jimny electrical problems
  • 1066Boy
16 Dec 2017 18:23 #187549 by 1066Boy
Replied by 1066Boy on topic Jimny electrical problems
Surprised you did not notice the crack when you pulled out the fuses to polish them Dan. :)
  • Daniel30
16 Dec 2017 19:17 #187555 by Daniel30
Replied by Daniel30 on topic Jimny electrical problems
Probably done it when I had the dremel polishing pads on the fuse buffing it up :P ;) :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
  • Mads
18 Dec 2017 14:51 #187597 by Mads
Replied by Mads on topic Jimny electrical problems
I can't figure this out.
If I turn on the seat heater, try to open / close electric window, fan, or rear window heater the main lights goes off. Apparently the stuff that I'm trying to turn on won't work. Any clues? Pointers?
18 Dec 2017 14:57 #187598 by mlines
Replied by mlines on topic Jimny electrical problems
Do you mean the switches no longer function or just the switch lights go out
The switches you mention are all common to the main lighting circuit
  • Mads
18 Dec 2017 16:01 #187601 by Mads
Thanks milnes.
Maybe I was a little unclear regarding previous post.
They are not functioning on activation, that being said when pressing the switch the lights goes out (main / head lights).
When turning on the head / main lights stays on regarding pressing the switches or not - but the function on the switch won't work. I can see of your diagram that everything is connected to the main light, but should I check ground for each switch? or is it connected to a reley or similar?
19 Dec 2017 15:40 #187621 by Busta
Replied by Busta on topic Jimny electrical problems
Have you wired any accessories into your Jimny? Lights, CB radio etc.
Time to create page: 0.105 seconds
