Jimny electrical problems
  • Mads
15 Dec 2017 09:23 #187476 by Mads
Jimny electrical problems was created by Mads
Good morning,
This is my first post so go gentle with me...
I have a suzuki jimmy with some electrical issues. The heater blower won't work, but the interesting part is when I try to turn it on the main lights goes off, if I turn on the seat heater the lights goes off etc. What could be the issue? bad grounds, or maybe a rele?
Went over the fuses inside the car, only one was blown (to the seat warmer). Is there any more fuses I should check? Engine bay?
Would be great if someone could post some pointers, and maybe pictures of what I should check out :-)
Have a great day!
15 Dec 2017 10:26 #187480 by Lambert
Replied by Lambert on topic Jimny electrical problems
Wierd stuff like that is usually an earthing fault. Wouldn't like to say which one though, a systematic review of them reference to a wiring diagram would be the first step.
The following user(s) said Thank You: Mads
  • Mads
15 Dec 2017 13:54 #187483 by Mads
Replied by Mads on topic Jimny electrical problems
Thanks,
OK. Is there any wiring diagrams on this site for the car?
I will go over and check each and single one.
I can hear it click in the rele underneath steering column.
  • mickt
15 Dec 2017 19:12 #187498 by mickt
Replied by mickt on topic Jimny electrical problems
If you can hear the relay clicking then maybe the blower fan has seized!
  • Mads
16 Dec 2017 08:45 #187520 by Mads
Thanks for the input Mickt,
But when I try to start the fan, or anything else (seat heater) all the lights goes off....
I mean every light, and then won't turn back on before i "shut down" the fan, or turn on the main lights with the switch on the left side.... Very strange thing.. Im giving two cents that it is ground problems.
  • Daniel30
16 Dec 2017 09:43 #187522 by Daniel30
Replied by Daniel30 on topic Jimny electrical problems
Did you have a good look at all the fuses, I had one on another car years ago that had just a hairline crack in it, it wasn't obvious that it had blown
Time to create page: 0.101 seconds
