Jimny electrical problems
- Mads
15 Dec 2017 09:23 #187476
by Mads
Jimny electrical problems was created by Mads
Good morning,
This is my first post so go gentle with me...
I have a suzuki jimmy with some electrical issues. The heater blower won't work, but the interesting part is when I try to turn it on the main lights goes off, if I turn on the seat heater the lights goes off etc. What could be the issue? bad grounds, or maybe a rele?
Went over the fuses inside the car, only one was blown (to the seat warmer). Is there any more fuses I should check? Engine bay?
Would be great if someone could post some pointers, and maybe pictures of what I should check out
Have a great day!
Have a great day!
- Thank you received: 2004
15 Dec 2017 10:26 #187480
Replied by Lambert on topic Jimny electrical problems
Wierd stuff like that is usually an earthing fault. Wouldn't like to say which one though, a systematic review of them reference to a wiring diagram would be the first step.
The following user(s) said Thank You: Mads
- Mads
15 Dec 2017 13:54 #187483
by Mads
Replied by Mads on topic Jimny electrical problems
Thanks,
OK. Is there any wiring diagrams on this site for the car?
I will go over and check each and single one.
I can hear it click in the rele underneath steering column.
- mickt
15 Dec 2017 19:12 #187498
by mickt
Replied by mickt on topic Jimny electrical problems
If you can hear the relay clicking then maybe the blower fan has seized!
- Mads
16 Dec 2017 08:45 #187520
by Mads
Thanks for the input Mickt,
But when I try to start the fan, or anything else (seat heater) all the lights goes off....
I mean every light, and then won't turn back on before i "shut down" the fan, or turn on the main lights with the switch on the left side.... Very strange thing.. Im giving two cents that it is ground problems.
16 Dec 2017 09:43 #187522
Replied by Daniel30 on topic Jimny electrical problems
Did you have a good look at all the fuses, I had one on another car years ago that had just a hairline crack in it, it wasn't obvious that it had blown
Time to create page: 0.104 seconds
