Jimny "Hiccups" in Idle
- Adama
18 Feb 2016 06:43 #162596
by Adama
Replied by Adama on topic Jimny "Hiccups" in Idle
Rhinoman, are you saying that these hiccups are by design?
What exactly is happening in the engine?
What is mode 06 everyone is talking about?
18 Feb 2016 09:40 #162607
by facade
Just me
Mode 06 is an advanced diagnostic mode that gives access to the raw data such as running counts of misfires per cylinder.
You need an advanced scantool, as
1) the data is vehicle specific
2) it is presented in hexadecimal.
The vehicle specific part is the problem here, as suzuki don't support much of it via generic OBD, you need the suzuki specific diagnostics to access it.
The cylinder misfire is interesting, as it looks at the change in engine speed as each cylinder fires. If this doesn't match then it flags a misfire against the cylinder. It maintains a running count of misfires, and if the exceed a set % of firing cycles, it sets the MIL and stores a P030X code, otherwise they usually forget the data when the ignition is switched off. I wanted to use this to see if I had a cylinder down, without getting my hands dirty
Replied by facade on topic Jimny "Hiccups" in Idle
Adama wrote: What is mode 06 everyone is talking about?
Just me
- Adama
18 Feb 2016 15:01 #162634
by Adama
I am going to try BG 44k
Anybody have any prior experience with this stuff?
18 Feb 2016 17:11 #162641
by facade
I think the consensus is if you've not tried it, it is expensive snake oil, if you have tried it it is the best magic fluid ever.
I don't normally bother with magic fluids, but I once put something called Profi-max in my 'bike, and it cleaned out the jets a treat, and saved me stripping the bike to get the carbs off. Only time a magic fluid has ever worked for me.
Give it a go if you want, but mine misses the odd beat at idle, as do a fair few others by all accounts, so you may be trying to fix something that isn't broken.
18 Feb 2016 19:31 - 19 Feb 2016 08:10 #162651
by Busta
Replied by Busta on topic Jimny "Hiccups" in Idle
I take it BG 44 is some kind of fuel additive? It won't help clean your throttle body or idle control valve.
Last edit: 19 Feb 2016 08:10 by Busta.
- Adama
19 Feb 2016 09:42 #162667
by Adama
I gave it a try yesterday.
My hiccups were GONE within 10minutes of running idle with this stuff!
My jimmy has been suffering from this annoying issue for the last 4 months.
During this time I have replaced:
Sparks
Coils
Pcv valve and vacuum hoses.
Air filter
Cleaned maf sensors
My next stage was IAC cleaning/replacement.
So it turns out that there are some good products that really work.
Unbelievable.
I strongly recommend to try it out
Sparks
Coils
Air filter
Cleaned maf sensors
Unbelievable.
Time to create page: 0.969 seconds
