Jimny "Hiccups" in Idle
19 Feb 2016 09:58 - 19 Feb 2016 10:00 #162668 by facade
Replied by facade on topic Jimny "Hiccups" in Idle
facade wrote: if you have tried it it is the best magic fluid ever.
Told you so B)
Last edit: 19 Feb 2016 10:00 by facade.
The following user(s) said Thank You: Adama
19 Feb 2016 10:20 #162672 by Busta
Replied by Busta on topic Jimny "Hiccups" in Idle
Sounds like you had dirty injectors then. Glad you got it sorted.
  • Adama
19 Feb 2016 10:55 #162674 by Adama
Replied by Adama on topic Jimny "Hiccups" in Idle
Dirty injectors clogged fuel pump who knows?
It is a magic fluid , now every 6 months I shall pour this stuff !
19 Feb 2016 12:41 #162676 by Busta
Clogged injectors are the only thing* on the fuel side that would affect the idle without causing big issues at higher engine speeds. If the fuel pump or anything else was clogged up it would initially cause issues at high rpms, where fuel and air flow are highest.
Magic is always a good way to fix things though. Which magic fuel additive would fix my kingpin bearings?
*maybe exhaust sensors too? Does this potion fix them?
19 Feb 2016 13:29 #162678 by facade
Busta wrote: *maybe exhaust sensors too? Does this potion fix them?
Supposed to, it is a concentrated detergent (polyether-amine en.wikipedia.org/wiki/Techron ) , like paying the extra for V-power or similar but all at once.
Actually, I've sent off for a can :ohmy: see if it can fix mine.
Remember that magic fluid they used to advertise on the TV, that would sharpen and set the blades on completely worn out hacksaw blades, just by dipping them in? I always wanted some.........
  • Adama
19 Feb 2016 15:31 #162679 by Adama
I can only recommend the BG 44k.
I am VERY sceptic when it comes to these additives and only after a long research I decided to try it.
It worked like magic.
As I understand it cleans up the fuel system.
I cannot recommend anything else sorry.
But I do suggest to try it if you have a hard idle.
