Jimny "Hiccups" in Idle
19 Feb 2016 15:50 #162682 by facade
Replied by facade on topic Jimny "Hiccups" in Idle
Adama wrote: I can only recommend the BG 44k.
But I do suggest to try it if you have a hard idle.
I was serious, I've sent off for some. Mine has done over 100,000 miles, mainly on supermarket petrol, and I have heard great things of BG44K, like I said, everyone who has tried it says it is brilliant, but at nearly £20 a can, it is expensive to just pour in on the off chance it will do something. (But if I had just spent £20 on magic fluid, likely I'd notice a difference too ;) )
Trouble is, all that carbon will drop off and end up in the catalyst :S
19 Feb 2016 19:54 #162687 by Rhinoman
Replied by Rhinoman on topic Jimny "Hiccups" in Idle
The ECU flicks the EGR open for a moment to check for a change in manifold pressure which indicates that its working, if the EGR is sticky then you will get more of a dip but its not really an issue.
27 Feb 2016 14:40 #163045 by facade
As a follow up, I traded my cow for a tin of magic fluid (BG44k)
I excitedly put half of it in, (as it does 75 litres, and I've only got about 20) and went for a run @3500 rpm for 25 miles.
Made no difference whatsoever :(
I want my cow back :)
  • Daniel30
27 Feb 2016 15:05 #163046 by Daniel30
Replied by Daniel30 on topic Jimny "Hiccups" in Idle
PANTS!! No golden egg for you :silly: :blink: :)
27 Feb 2016 15:21 #163047 by Busta
Replied by Busta on topic Jimny "Hiccups" in Idle
That's unfortunate Facade. Magic stuff isn't cheap!
  • Adama
27 Feb 2016 15:25 #163049 by Adama
Replied by Adama on topic Jimny "Hiccups" in Idle
Too bad
But why not according to the instructions?
Full gas tank with a full bottle.
For me it did wonders.
Time to create page: 1.578 seconds
