Undoing crank pulley bolt?
- Thank you received: 614
21 Jan 2016 15:18 #160775
by facade
Undoing crank pulley bolt? was created by facade
It finally happened to me, crank pulley fell apart, and I came home on the back of an AA van.
(What a stupid design, it is obviously going to fail, as the fan belt tension acts to flip the pulley off the spindle.)
I got a new pulley (sorry Martin, I need to fix it right now this minute)
But I can't undo the crank bolt.
I made this
and I've got a 4 foot long bar on the socket, but all that happens is the bar is bending.
I have a windy gun that is supposed to do 235ftlb, but that doesn't make any effort to undo it, but I suspect that is because I have 2 extension hoses and it isn't getting enough air.
I've sprayed round the flange on the bolt with GT-85
All that is left is to wait until I can get a mate round, bend the 4 foot bar double and hold the strain on, and get him to whack the socket end.
Any suggestions from all you folks who have managed to undo it?
I suspect the old using the starter and let the spanner flail round to hit the chassis dodge isn't going to work on this one....
I made this
- mickt
- Visitor
21 Jan 2016 15:31 #160777
by mickt
Replied by mickt on topic Undoing crank pulley bolt?
I used my battery impact gun with a fully charged battery. First press and bingo. The starter motor trick is good as long as the driven arm only moves 90 degrees. Its best if somebody keeps a push on the socket to the bolt head while the switch is operated for the second it takes to engage the motor. Obvious safety awareness required!.
21 Jan 2016 17:56 - 21 Jan 2016 18:02 #160799
by facade
Replied by facade on topic Undoing crank pulley bolt?
Cheers, I was hoping someone would have a little tip.
I wonder if it has been done before and some idiot has put loctite on the threads when assembling?
It is only supposed to be 108 ftlb, I must have got over 400 on the end of that bar, I'm frightened I will shear the head off, split the socket or shear off the square drive.
The only way to shift that is to stick weld to the bolt head, and hope the bolt gets enough heat down its length to melt it.
But then I'll never get the socket on after.........
I can get the blowlamp to the bolt head, but most of the heat will just go into the pulley,
Stuck now until I can get someone round to help on Saturday.
A replacement engine would have been less trouble, and probably only twice the cost of the pulley :evil:
Last edit: 21 Jan 2016 18:02 by facade.
21 Jan 2016 18:09 #160802
by Busta
Replied by Busta on topic Undoing crank pulley bolt?
I've had no problem with a 3ft breaker bar, even with the engines out of the car, rolling about on a trailer floor. If your bar is bending, get a stronger bar!
21 Jan 2016 18:10 #160803
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Undoing crank pulley bolt?
Have you tried the socket long bar and flicking the starter?
Grey pick up Jimny
21 Jan 2016 18:39 #160809
by facade
No, I need someone to operate the starter while I watch what happens/ keep the socket on, but how tight this is it will probably twist the crank before it goes. :S
Busta, I do have a 3/4 drive bar, and a reducer to 1/2" somewhere, I don't have a 17mm 3/4 drive socket though. I've got a 2' Draper cracker bar and 3' of thick walled tubing, but the cracker bar bows like a banana unless I slide the tube right down.
It must be loctited. :pinch:
I can try the blowlamp on the head on Saturday, other than that I will have to slip the radiator in and drive it nearer my compressor to use a shorter pipe and let the windy gun hammer away for a while and hope it eventually breaks free.
If the head shears off and leaves the thread stuck or loctited in the crank I will really be in trouble.
(I'm in trouble now as I can't use it anyway with no waterpump drive)
j999pre wrote: Have you tried the socket long bar and flicking the starter?
Time to create page: 0.204 seconds
