Undoing crank pulley bolt?
  • helijohn
  • Visitor
  • Visitor
21 Jan 2016 19:42 #160813 by helijohn
Replied by helijohn on topic Undoing crank pulley bolt?
facade wrote: It must be loctited. :pinch: I can try the blowlamp on the head on Saturday, )
What a nightmare. I think I would have tried the heat by now and defo an impact wrench.
21 Jan 2016 22:11 - 21 Jan 2016 22:13 #160826 by Jezz
Replied by Jezz on topic Undoing crank pulley bolt?
If you end up going down the welder route, Get a nut large enough to fit over the bolt head and weld on, then you still have the new welded on nut to get a socket on. Similar to the photo.
It's been fettled just a tad.
Last edit: 21 Jan 2016 22:13 by Jezz. Reason: spelling
22 Jan 2016 06:35 #160840 by Lambert
Replied by Lambert on topic Undoing crank pulley bolt?
If it is lock tighted then a small amount of heat should destroy the bond it shouldn't need to be red or yellow hot to get it out. Assuming that that is the problem. If it has been crossed and wound up with a windy gun you are looking at re tapping the crank. Good luck.
  • OllieNZ
  • Visitor
  • Visitor
22 Jan 2016 09:29 #160848 by OllieNZ
Replied by OllieNZ on topic Re:Undoing crank pulley bolt?
Mine was corroded in and took some shifting, 2ft breaker bar plus a lump hammer. The impact force goes a long way to help getting it undone.
23 Jan 2016 13:29 #160921 by facade
Replied by facade on topic Undoing crank pulley bolt?
Can't move it!
It isn't a left hand thread is it?
Got mate pulling with all his weight on the 4 foot bar, I thought the engine mountings would rip apart, and then belted the bar close to the socket with a lumphammer. Not the slightest movement. (Apart from I now have a permanent bend in the bar)
Warmed the bolt until it glows red, and the rubber on the pulley smokes, and tried again, nothing. (probably wrecked the oilseal now)
Looks like a major operation now, make a drill guide and centre drill the head off, then if the thread is seized drill that out and clean the threads up. Bumper off to do that though.
Last chance is next door's son in law is a breakdown mechanic, and probably has a powerful electric impact gun, he comes round to see them tomorrow.
  • helijohn
  • Visitor
  • Visitor
23 Jan 2016 17:55 #160966 by helijohn
facade wrote: Can't move it! Warmed the bolt until it glows red,
I wouldn't have heated it that much - unless it pigged me off. :laugh: :laugh:
Time to create page: 0.196 seconds
