Undoing crank pulley bolt?
30 Jan 2016 02:04 - 30 Jan 2016 02:06 #161471 by facade
Replied by facade on topic Undoing crank pulley bolt?
Incidentally, my jimny had started to make A Noise when revved hard in first gear to pull away sharply, a sort of graunchy buzzy howl, just like a worn needle roller in the gearbox. (I was going to buy a set of bearings and rebuild the gearbox when I do the clutch this Summer, I'd checked for loose heatshields and stuff already))
It seems to have stopped now, and I notice at least half of the rubber left on the pulley is all polished :whistle:
Last edit: 30 Jan 2016 02:06 by facade.
  • Daniel30
  • Visitor
  • Visitor
30 Jan 2016 08:40 #161475 by Daniel30
Replied by Daniel30 on topic Undoing crank pulley bolt?
Glad you have finally got it sorted
Well done in turning your pain into other people's gain by writing up a great thread about the problem ;)
30 Jan 2016 09:01 #161476 by facade
Cheers,
If I'd known the old one was breaking loose, I could have run superglue round the splitline and repaired it. while it was still on ;)
still, If I'd known how easy chopping the washer off would make it I'd have just bought the new bolt and had it changed a week ago :whistle:
  • mickt
  • Visitor
  • Visitor
30 Jan 2016 11:36 #161484 by mickt
Replied by mickt on topic Undoing crank pulley bolt?
SOTA don't forget to ensure all the pulleys grooves are free from debris i.e. rubber, rust etc by wire brushing them till they are shiny!
  • gusthegorilla
  • Visitor
  • Visitor
30 Jan 2016 12:01 #161491 by gusthegorilla
Replied by gusthegorilla on topic Undoing crank pulley bolt?
Absolutely first-class 'how-to', facade.....could accrue a huge number of hits in no time at all. :woohoo:
  • SOTA
  • Visitor
  • Visitor
30 Jan 2016 14:05 #161494 by SOTA
Replied by SOTA on topic Undoing crank pulley bolt?
Fantastic how-to, thanks for the details.
Not sure when I'll get space to carry out repairs, I've refilled the water. With no water pump spinning will it be safe to start the engine just to manoeuvre the jimny into a place where I can work on it?
No longer than 30 seconds running time.
