bad vibrations
15 Dec 2015 17:52 #158577
by Busta
Replied by Busta on topic bad vibrations
15 Dec 2015 18:02 #158578
by kirkynut
Replied by kirkynut on topic bad vibrations
If the prop has been split at some point it might have been put back together differently so it's out of balance too. It might therefore be "Out of Phase" as suggested by Busta above or just that the balancing weight is now in the wrong place.
Under the rubber gaiter there's a dot stamped on each side of the prop in the centre. They need to be lined up for it to be together correctly. You pretty much have to split it to see these though.
Hopefully it's that as it's a free fix!
- Johnniehec
- Thank you received: 56
17 Dec 2015 21:45 #158696
by Johnniehec
Replied by Johnniehec on topic bad vibrations
If your steering wheel's not shaking it's not death wobble, don't touch your kingpins!!!!
Time to create page: 0.087 seconds
