bad vibrations
  • rexthecat
10 years 11 months ago #158517 by rexthecat
bad vibrations was created by rexthecat
So noticed at the weekend, having fitted manual hubs, if I leave the hubs engaged and drive in 2H between between 40 and 50 I get loud rumbling / vibrations, feels like its maybe from the tyres or shaft. Set the hubs to free and the vibrations go away....mostly.
Could be wheel wobble, but the steering wheel doesn't judder around. I need to get the tracking done anyway and thought id get some shims for the kingpins see if that cures it, but can anyone else think of a likely cause.
Just seems to happen in 4th and 5th gear and only when it has gas, lift off and over run a little and seems to go away.
Im wondering if its something to do with the transfer box or the drive shaft? Or would having hubs engaged worsen the effect of wheel wobble?
ta
10 years 11 months ago #158518 by j999pre
Replied by j999pre on topic bad vibrations
Could be front prop uj. This wouldn't turn if you unlock the hubs
Grey pick up Jimny
10 years 11 months ago #158519 by Lambert
Replied by Lambert on topic bad vibrations
If it is death wobble from the kingpins it would be permanently happening. As there is a significant difference between hubs in and out I would have a look at the front prop joints for.starters then from there work through the axle and then the transfer box. Always look at the cheapest and most accessible things first.
  • rexthecat
10 years 11 months ago #158556 by rexthecat
Replied by rexthecat on topic bad vibrations
Grand, thanks both, reckon uJ sounds place to start.
Cheers
  • TomDK
10 years 11 months ago #158557 by TomDK
Replied by TomDK on topic bad vibrations
rexthecat wrote: So noticed at the weekend, having fitted manual hubs, if I leave the hubs engaged and drive in 2H between between 40 and 50 I get loud rumbling / vibrations, feels like its maybe from the tyres or shaft. Set the hubs to free and the vibrations go away....mostly.
ta
I have the same problem if I drive in 4H with hubs disengaged. Apparently the front prop is not very well balanced :)
10 years 11 months ago #158576 by kirkynut
Replied by kirkynut on topic bad vibrations
I read the first post and thought prop out of balance. It could be play in a UJ but I'd expect it to clonk when drive is taken up in 4wd.
Have a look to see if there are any obvious signs of a balancing weight having fallen off. It will be a clean square patch or four mini weld blobs where it was once held on in the corners of the balancing weight.
