bad vibrations
- rexthecat
Could be wheel wobble, but the steering wheel doesn't judder around. I need to get the tracking done anyway and thought id get some shims for the kingpins see if that cures it, but can anyone else think of a likely cause.
Just seems to happen in 4th and 5th gear and only when it has gas, lift off and over run a little and seems to go away.
Im wondering if its something to do with the transfer box or the drive shaft? Or would having hubs engaged worsen the effect of wheel wobble?
ta
Grey pick up Jimny
- Thank you received: 2004
- rexthecat
Cheers
- TomDK
rexthecat wrote: So noticed at the weekend, having fitted manual hubs, if I leave the hubs engaged and drive in 2H between between 40 and 50 I get loud rumbling / vibrations, feels like its maybe from the tyres or shaft. Set the hubs to free and the vibrations go away....mostly.
ta
I have the same problem if I drive in 4H with hubs disengaged. Apparently the front prop is not very well balanced
Have a look to see if there are any obvious signs of a balancing weight having fallen off. It will be a clean square patch or four mini weld blobs where it was once held on in the corners of the balancing weight.
