Welding helmets
  • helijohn
07 Dec 2015 11:22 #158027 by helijohn
Replied by helijohn on topic Re:Welding helmets
OllieNZ wrote: They still have a battery it's just rechargeable. One of the guys at work bought one of the cheap eBay ones and loves it. I do find the variable darkness useful.
Some helmets don't have any batteries at all and just rely on the solar cell - is that right? And some of the rechargeable ones need recharching before they can be used - is that right?
  • OllieNZ
07 Dec 2015 11:31 #158028 by OllieNZ
Replied by OllieNZ on topic Re:RE: Re:Welding helmets
Tbh not 100% sure now. With out a power source of some description they will not be able to dim so the solar power ones still need an initial charge to come from somewhere. Afaik they have an internal battery that is charged by the panel. This battery is not replaceable so if it fails you need to replace the unit.
  • gilburton
07 Dec 2015 11:48 - 07 Dec 2015 12:01 #158030 by gilburton
Replied by gilburton on topic Welding helmets
I've had a cheap ebay one for years and it still works.
Don't ask me about the technical side so i don't know if it has a battery or not all I know is that I can pick it up after months or years and it still works.
It just reacts to light.
It'll even react to the garage lights or a candle.
You can adjust the darkness to suit arc or gas or mig.
After years of welding with a fixed lens it was a massive improvement. I was a bit wary at first "wiill it work"?? as I( didn't want flash in my eye)but it allows you to accurately align your welding torch/stick/rod and you are away.
It comes with spare plastic (not clear glass) visor shields so if you are welding up close they don't last long but perfectly adequate for the "hobby" welder.
If you are welding on a regular basis best to get something more expensive.
Last edit: 07 Dec 2015 12:01 by gilburton.
  • helijohn
07 Dec 2015 11:54 #158031 by helijohn
Replied by helijohn on topic Re:RE: Re:Welding helmets
The solar only ones often make no mention of batteries.
I am right this minute looking for one that uses regular batteries like AAA for example without paying an arm and a leg.
  • gilburton
07 Dec 2015 12:10 - 07 Dec 2015 12:12 #158033 by gilburton
They work straight out of the box so no charging to do at all. They just react to the light. No need for batteries and there is no provision for changing anything.
Forget batteries they work and you don't get any flash as they react very quickly.
I've had mine over 5 yrs and it lies in a box in the garage and it's never failed yet.
If it had a battery of any sort it would be dead. Keeping it simple they get the power from the light and that's it!!
Put it this way if you used it occasionally it'll be years before anything fails and at the price they are now it'll still be cheap to replace.
Last edit: 07 Dec 2015 12:12 by gilburton.
  • gilburton
07 Dec 2015 12:26 - 07 Dec 2015 12:38 #158034 by gilburton
Ok I've just looked up "welding helmet battery" and it would seem that the "lithium" battery we are talking about is the button type battery you fit in the key fob.
Some have one others have two but either way we are not talking about expensive batteries IF they ever need replacing at all??
As I understand it the battery is just there for standby.
The lens is an LCD sandwiched between polarized lenses. Basically they bend the light so that you don't see the brightness.
It reacts to the light without any power at all. It's not getting a charge from the light it's just a reaction.
Chinese quality aside just go ahead and buy one with confidence.
Whether you want one with a skulls head or flashy graphics is up to you :laugh: :laugh:
Last edit: 07 Dec 2015 12:38 by gilburton.
Time to create page: 0.136 seconds
