Welding helmets
- gilburton
26 Dec 2015 11:16 - 26 Dec 2015 11:18 #159120
by gilburton
Replied by gilburton on topic Welding helmets
Mine will go dark if I look at the flourescent garage lights??
Is there a protective layer of plastic film on the lens that needs to be removed?
Last edit: 26 Dec 2015 11:18 by gilburton.
26 Dec 2015 12:14 #159121
Replied by helijohn on topic Welding helmets
Plastic films have been taken off.
I set the sensitivity and delay dials to a lot of combinations including hi sensitivity and middle setting delay.
I googled how to test it yesterday and came up with various methods. It even states in the destructions how to test it
"You can struck(sic) a light or match to test the lens before struck an arc on the working piece". It says not to use it if the lens is not operating properly but I don't need telling twice. :blink:
There is no sun - predictably. Plenty of rain though.
Flourescents did it!!. :woohoo:
Operator error I guess. :blush:
Next .......................the knob on the side which is about ambient lighting. It seems to make a tiny bit of difference to the darkening while it is idle so will it be best left halfway?
- gilburton
26 Dec 2015 12:21 - 26 Dec 2015 12:36 #159122
by gilburton
You'll probably find it's like a washing machine. Leave everything on medium :laugh: :laugh: :laugh:
I never touch mine on arc or mig. Just test it out on a middle setting and adjust to suit. Unless you will be using a flame based weld in reality it'll suit most small jobs.
They usually recommend some ambiguous settings depending on the weld being used but as with all things eyes and personal preferences are different.
I was dubious when I first tried mine and I sort of squinted half looking away but nothing to worry about.
Last edit: 26 Dec 2015 12:36 by gilburton.
26 Dec 2015 22:23 #159163
by Busta
Replied by Busta on topic Welding helmets
You won't be able to set the brightness up until you are actually welding. Set it so it's bright enough to see what you are doing. Simple as that.
26 Dec 2015 22:55 #159170
Gottit thanks.
Busta wrote: You won't be able to set the brightness up until you are actually welding. Set it so it's bright enough to see what you are doing. Simple as that.
Gottit thanks.
