Welding helmets
My solar powered one just works as stated above, and it lives in a dark box to protect it from dirt 99.999% of the time
Flash burns are basically when your cornea gets a suntan.
- irishguy123
The only time it annoys me is when I have it set on the grinding setting and then fire up the mig, you end up with the floating blue spots for a few minutes. :pinch:
gilburton wrote: Ok I've just looked up "welding helmet battery" and it would seem that the "lithium" battery we are talking about is the button type battery you fit in the key fob.
Some have one others have two but either way we are not talking about expensive batteries IF they ever need replacing at all??
As I understand it the battery is just there for standby.
The lens is an LCD sandwiched between polarized lenses. Basically they bend the light so that you don't see the brightness.
It reacts to the light without any power at all. It's not getting a charge from the light it's just a reaction.
Chinese quality aside just go ahead and buy one with confidence.
Whether you want one with a skulls head or flashy graphics is up to you :laugh: :laugh:
That's informative. I tried to find this out but obviously need more abilities. So from what you say the lens basically reminds me of reactolite sunspecs. :laugh: :laugh:
So I don't need batteries and don't want them cos the helmet will sit in a box for months. Excellent.
- gilburton
The batteries are supposed to be good for thousands of hrs and some are replaceable but they are part of the visor so some surgery may be required.
They switch off if not using the helmet and are just there to kickstart the electronics and then the welding light takes over.
It all happens in milliseconds so there is no heavy demand on the battery.
I did read a post where it's around 3000 hrs which is a lot of welding.
Look how long watch batteries last and they are working all the time.
If/when the battery goes it fails safe in "dark mode!
At the prices helmets are now they are virtually throw away items these days as mine was nearer £50 but £20 is about the average prices on ebay (cheap ones).
You can still get "battery powered" ones but they tend to be more at the expensive end of the market and you have to switch them on before welding although they auto switch off.
Some of these posts are a few years old and technology/prices have moved on so may not be 100% accurate.
- mickt
