replacement wheel hub studs
14 May 2015 17:43 #144210 by Jezz
Replied by Jezz on topic replacement wheel hub studs
Yes your correct Gus, When I've done it in the past I ran a drill through the hole to open it up to the right size.
It's been fettled just a tad.
  • X8GGY
14 May 2015 17:43 #144211 by X8GGY
Replied by X8GGY on topic replacement wheel hub studs
gusthegorilla wrote: Jack, I just remembered...it's not the 1.25 that's the problem, it's the 12.35 spline dia.
Jezz is right , they are on ebay......in every size except 12.35 :whistle:
Too true... I've STILL got some Subaru extended studs in stock, as I too discovered the splined section was too big, even though the threaded bit is ok...
14 May 2015 17:53 #144213 by jackonlyjack
thanks guys different approach time
can you tell me length of thread on spacers
i need at least 25mm to work with
tar
  • X8GGY
14 May 2015 17:55 #144214 by X8GGY
Do JimnyBits make their own wheel spacers?
They may have suitable studs then? :)
  • X8GGY
14 May 2015 18:11 #144216 by X8GGY
OD of stud splines is 14.3mm and the threads are 43mm
I've got 33 for some reason?!
  • gusthegorilla
14 May 2015 18:24 #144219 by gusthegorilla
Replied by gusthegorilla on topic replacement wheel hub studs
So run out 2mm like Jezz did with a drill, knock these old things in from the back, and get out the welder....sorted :whistle:
Time to create page: 0.143 seconds
