replacement wheel hub studs
14 May 2015 16:52 #144204 by jackonlyjack
hi just got some vit alloys and need longer studs
they need to be 10mm longer
can anyone tell me the standard length and spline size needed
thanks
jack
  • gusthegorilla
14 May 2015 17:09 #144205 by gusthegorilla
Replied by gusthegorilla on topic replacement wheel hub studs
Hi, Jack....
Std studs : M12x1.25x 30mm
Spline dia : 12.35mm
Good luck finding them, though mate....Months ago I had to ditch £250 worth of 30mm spacers 'cos the standard studs are 8mm short of being in safety, tried absolutely everywhere to get longer ones, even as far away as Oz, without luck.
(It's the 1.25 that's the problem....boatloads of 1.5's available.
I ended up getting a quote from a stud manufacturer to make me a 1-off batch of 44......£218 +p/p !! :sick:
If you have any more success than I did, PLEASE LET ME KNOW !!!
Hope this helps,
Chris :)
14 May 2015 17:17 - 14 May 2015 17:21 #144206 by Jezz
Replied by Jezz on topic replacement wheel hub studs
You can get them on e-bay. Type in m12x1.25mm wheel studs.
It's been fettled just a tad.
Last edit: 14 May 2015 17:21 by Jezz. Reason: spelling
14 May 2015 17:18 #144207 by jackonlyjack
thanks Chris
i have about 11mm of thread
sticking out to bolt onto
i think it a little amount to be safe :unsure:
  • gusthegorilla
14 May 2015 17:21 #144208 by gusthegorilla
Jezz wrote: You can get them on e-bay.
You got a link please , Jezz?
  • gusthegorilla
14 May 2015 17:25 #144209 by gusthegorilla
Jack, I just remembered...it's not the 1.25 that's the problem, it's the 12.35 spline dia.
Jezz is right , they are on ebay......in every size except 12.35 :whistle:
Time to create page: 0.112 seconds
