replacement wheel hub studs
Topic Author
- Thank you received: 706
14 May 2015 18:41 - 14 May 2015 18:47 #144221
Replied by jackonlyjack on topic replacement wheel hub studs
just sent a ticket to Rus
the jim owner with union jack flag on bonnet/down ns wing
as same wheels that i picked up maybe he can help anyone know him ?
Last edit: 14 May 2015 18:47 by jackonlyjack.
- mickt
14 May 2015 19:21 #144224
by mickt
Replied by mickt on topic replacement wheel hub studs
The smaller studs are obviously not strong enough to take the extra load when lengthened hence the increase in diameter. The loading on the bearings is of course substantially increased as a result of the wider wheel too.
Topic Author
14 May 2015 20:16 #144229
only running 195's
it's just the alloy is much thicker
only leaving around 11mm for the nut to go on
mickt wrote: The smaller studs are obviously not strong enough to take the extra load when lengthened hence the increase in diameter. The loading on the bearings is of course substantially increased as a result of the wider wheel too.
only running 195's
15 May 2015 10:57 #144236
Replied by mlines on topic replacement wheel hub studs
Some SJs were fitted with longer studs, probably due to wheels that were fitted. It is possible to find these studs but its not easy. I have some on my Jimny and will take a picture if I remember to show they exist (P.S I am still one short for my own collection!)
15 May 2015 12:12 #144237
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic replacement wheel hub studs
The front studs are generally longer to compensate for the thickness of the disc.
Time to create page: 0.109 seconds
